Rear valance 6n
I need to replace the rear valance on my P-reg 3 door. Is it a bolt-on part or is cutting and welding required?
  • Views 791
anybody know? don't want to take my rear bumper off until I've got all the bits ready.
The rear bumper? If so i think its just bolted on mate
Bolts on.
Remove the upper section of the bumper (screws are located inside rear arches and under the boot) then pull that off.
The lower valance unbolts but you need to UNSCREW the 4 plastic bit that the top part held onto before you can remove the bottom section properly :)
I learnt that bit the hard way :lol:
as lordOslek said, there a bolt on part, get your new one painted, put some protection on the other side of the pannel (i.e, stonechip/waxoil) to hep preserve the new pannel, and then simply swap over, the swap over should take around an hour for someone who hasnt done one before, but beware of seized nuts and bots, locate them all first and spray/soake in wd40 just to make for an easyer job
