MK3 Polo GT query.
Hi all, new to the forum and have a few questions I hope some can answer. Basically I'm going to have the opportunity to buy a new car in the next few months and i'm looking at getting a MK3 polo GT but having not owned any older VW's before i'm not wanting to jump in blindly to getting one. I'm pretty much going to be buy one as standard as possible and doing a couple of choice mods and really what I want to know is;
Are there any bad points to look out for?
How hard is servicing? (i've only owned a ford focus in the past which was easy to do basic servicing on)
I'm planning to lower the car and put a set of wheels on, how hard are coilovers to come buy?
I have a few mates that can help out with fitting the coilovers and servicing but i'm not wanting to rely on them whenever I need an oil change or some other mediocre task. Any help and or tips would be appreciated.
Cheers, Stuart.
  • Views 778
I am one of the people that jumped in blindly and bought one and I love it.
Things to check out would be the battery tray and just generally that area under and around the windscreen for rust.
Also if it still has the arch plastics on its quite likely that they will be hiding rust, then again its not like your gonna go ripping someone else's car to pieces when your viewing it haha.
There easy enough to work on, I mean its not like you will have trouble dropping the oil, replacing filters etc.
Coilovers are easy enough to come buy (new) off this very forum from a site sponsor, check out jackson tuning.
But be prepared to get your cash out because colies for coupes are very expensive. Due to the front suspension set-up and the fact that not many companies make them, infact I could be right in saying most of the time they are custom made and you have to send off your struts. But don't be put off by this, shocks and springs that fit can be picked up for decent prices plus they come in a good range of drops just check out this thread to see what drop you fancy:
http://www.clubpolo.co.uk/forum/index.php?...t=0&start=0
Hope I have helped.
Rust, everywhere. They go on the bottom of the doors, the sills and on the arches under the black plastic trim. Also worth looking out for cracked chassis legs - uncommon on a GT but not unheard of!
Battery trays also rot through and a pillars tend to bubble around the windscreen seal.
Other than that the big issue tends to be fuel filler necks. Once it's rotten you'll have to replace the whole tank.
Generally speaking though, they're not too prone to rust compared to others of the same age.
Piece of piss. Probably easier than a Focus. I'd do mine myself if I wasn't so lazy.
Depends how low you want to go. If you're not planning to get it corner weighted or have the sills on the floor, just get yourself a decent set of fixed rate dampers and springs and save yourself some money.
Coilovers aren't difficult to come by but as mentioned the front struts need to be specially made because the suspension design is toss. Here's my original strut vs my new Gaz coilover strut.
So you'll either need to find a set at a scrap yard or have your car off the road for a while!
The other issue you'll get with decking it is clearance for wheels. Polo arches are tiny, any decent offset will rub, and you'll need low profile rubber for almost anything you fit. Not easy but worth it.
Other things to consider:
- G40 brakes - GT brakes are wank. Swap the callipers for G40 spec units (easy to get hold of as they're on lots of cars - just look out for the VW II logo) and you'll get vented brakes. Same size, but less prone to fade. G40 brakes fit behind GT steel wheels - my advice, make this your first mod.
- Brake lines - Polo brakes aren't too hot anyway, don't add to that by leaving perished old rubber brake hoses on the car
- Anti Roll Bar mounts - g-laderseite.de sells nylon anti roll bar blocks which make a big difference to the way a Polo handles. A must-have.
- Track Control Arms - Check they're straight, I've bent two of them
- Signs of a break-in - screwdriver marks around the door handle, usually
- Blowers - check to make sure you've got three fan speeds and that the blowers don't just come on when switched to 3, or you'll have to replace the resistor block. Not too expensive or difficult to change but reasonably hard to come by as a lot of cars in scrap yards have broken ones.
Um... think that's it off hand.
Not the fastest cars, or the best handling, but they're great fun.
Edited by Alex
Coilovers are becoming cheaper these days and there's no need to send your strut off. There's a user on here who is selling mk1 golf coilovers with a full fitting kit so it's a bolt on job, these are around the same same price as other budget coilover kits but give more lows and give camber adjustment (some thing the standard setup doesn't have).
As said look out for rust, they are not particularly bad for it bit they do have some weak spots as mentioned. Also they are very simple cars so basic servicing is a piece of piss and they are very good cars to use to learn more about the mechanical side of things
If your going to lower it, then spend the money. Cheap kits really do make the car drive terrible. Very crashy ride. You will get fed up of it after a while.
Everyone is saying to look out for rust but I'm yet to have a GT with any major rust.
Places to check,
- Battery tray
- Around edges of windscreen, Particularly the passenger side bottom corner
- Sills at the rear (Prone to rotting when they fill with crap kicked up from the tyres
Check all the electrics, check the loom in the bay to check it hasnt been messed with at any point.
Get it up to temperature and check for obvious overheating, tapping, knocking from engine.
Suppose its preferance but id stray away from cheap modified examples. Past experience hasnt been great with them. Plenty of standard ones around if you take the time to look.
Servicing wise id say its the easiest car I've ever serviced. Will be much more straight forward than your focus.
Cheers for the feedback guys! Glad servicing ain't an issue here, was my main concern. Hopefully going to buy a standard car and do the work myself. I've actually not got my licence yet (was banned a few years back when I was a bit younger and a lot more stupid behind the wheel) so i'll be buying the car before i've passed so I can do a full service and whatever mods I decide to do. Cheers for all the input though, given me a better picture of what i'll be up against. Ill no doubt have more questions in future.
