1982 VW Polo C Formel E 1.1 £120 Little Work Needed Clean Car
This is a classic mk2 polo formel e.
It has the 1.1 litre high compression engine, 3+E gearbox, shift light and MPG meter, done around 80,000 miles.
The car is completely original and unmolested, the only new things are the clutch and petrol tank.
It currently doesn't have an MOT or TAX because there are a couple of things it needs doing to get it driveable.
Front brakes need bleeding,
Needs a new gearbox.
Carb needs tightening on the manifold and the accelerator and choke cables need attaching and timing needs to be set,
The outer arches are also a little rusty where mudflaps used to be, I have removed the
flaps and a little filler and sanding should sort it out, nothing structural though, doesn't stop the
car being used.
Apart from the above, the car is very clean with only a few minor bumps as you'd expect.
It is a rare version of the polo and is by far the most fun car I have owned, the engine is unbelievebly revy and makes
a wicked mechanical noise!! It was a daily driver until September when the clutch went, it has since been replaced but I have recently moved to London so no need for a car. I was in the process of refurbishing the bushes on the suspension etc. but lack of funds and life got in the way so it just needs a good home a a few hours to be enjoyed again.
Looking for around £120
YES that is blue carpet and blue vinyl on the seats, it has that amazing old car smell and a manual choke, not to
mention the original Wolfsburg steering wheel, and notice the single wingmirror to "reduce wind drag" and make it more economical :D (You get my point, this car ooozes character)(and the patch on the drivers seat is just were it has worn, the car is actually incredibly clean inside.)
The car is near Aldershot and will need to be trailered, call on 07515286767 if you want to come look or have any other questions.
This is in the car breaking area but since mattloaf posted here i though i'd give it another shot. Would be a shame to see this be eaten by the car muncher. £120, picked up ASAP. Would fix it myself but there's no time in life and I need wheels that work.
Edited by Driptap
  • 6 months later...
  • Replies 13
  • Views 926
For the love of christ someone save this.
Yea please save this someone
To be honest if I can get this shipped for a reasonable price I might just take it off you just to save it. Think you could knock the price down a bit if that is the case?
Thats a little cheeky matt! £120 is dirt cheap. If i didn't already have a rusting coupe on my drive, I would have this. My GFs been looking for a white breadvan since mine was written off :-(
119.99
I might take this off you, text me 07551834827
Pretty cool!!
I want the clocks!!
Eric you can have the clocks if you want I will have no need for them if he replies...
awhh yeeeh
Ite this thing has gotto go, its such a shame as the chassis has no rust anywhere and its higher quality Wolfsburg steel, erixtar PM me if you want the clocks i'll be keeping some other shit from it also, post in the breaking section, before I wave good bye to a fine example of a very early mk2 as it decends into the car graveyard (cry)
if i had a trailer sorted i would grab this mate
but just not got 1 atm
