VW Madness again
Went into VW today for my usual supply of top mounts (every 18 months) for my mk3, and they have discontinued them.
Great thanks VW, so ECP or GSF ones? are any better than the other, I only used to get 4-5 months out of ECP before, once got 3 weeks out of a pair (though they replaced them for free, i say free, i still had to do the donkey work!!!).
Now car is only 60mm down at front and I only do 5k per year, so what are my options?
This is for the daily G
Should I go and get some of Phil J's bonrath ones then?
Wait for the other ones Phil is working on?
Buy more ECP ones and just change them more often than my oil!!!! FFS!!!
What are other people doing?
  • Replies 10
  • Views 1.2k
Man you get through some top mounts... out of interest what used to wear on them? Just I've never changed mine and I think they are original from 1984 lol
Some people seem to have loads of issues with top mounts, i never see why :lol:
Mine, cheap GSF ones... done about 10K on them with next to no suspension. Still fine.
best get used to that. All mk3s are more than 15 years old now so VW are under no obligation to keep supplying spare parts. Lots of G40 parts are going obsolete now.
as for top mounts, get some G-Laderseite ones (well I guess you should called these MaxRPM ones now since the company has changed it's name). PPP are the UK dealer. They will last forever.
Same. Other people seem to go through them every few months.
the people who supply bearings to the motorfactor i use were having problems getting wheel bearings for older VW's last time i needed one.
Even on ebay the amount of new bits has dwindled. 2 years ago I needed TCA's and there were loads there, last august I needed some and I found 1 seller.
Easiest way to phase out old cars is to stop making parts for the i suppose.
I don't think it's a case of them wanting to actively phase out older cars but they are only obliged to keep supplying spares for cars for 15 years, that's now gone so it doesn't make sense from a commercial point of view to keep sourcing, buying, stocking, supplying etc... spares for old cars. There is a VW heritage place in Germany which tends to keep supplying parts for older VWs if the demand is there. It's just all part and parcel of owning an old car. Plenty of classics are only kept on the road because people have started companies sourcing or manufacturing replacement parts because the manufacturer either stopped doing so years ago or doesn't exist any more.
Only good if you own a Golf platform based car (flagship model) or an aircooled :lol:
I've only ever had to change one top mount on the 3 polo's I've owned and it turned out I didn't even need to do that (the movement turned out to be in the shock and not the top mount). I can't understand how people get through so many? :?
Think they assume the movement/gap in the top cap points to a worn out top mount.
I had to many mk2/3's now, many with orginal top mounts that where fine.
Even had a mk3 on 160k with untouched suspention (orginal shocks i was replacing) and the top mounts where still in good condition.
Some top mounts last longer than others, luck of the draw really. I have always found that when you fit aftermarket suspension, the top mounts aways wear quicker afterwards.
No not a gap at the top cap, they have that when new ones are fitted. I find I always get excessive movement in the top mounts, which causes knocking in the suspension.
Yes, I could go for solid ones from maxrpm or ppp, but a bit over the top for a daily, with the kids. Rose joints for the road, bit over the top really. May last a while but not for my daily G40, but I actually like some kind of comfort in the car and try to reduce road noise
Car is only 17 years old and I know of newer mk3's. Just surprised vw stopped them so quickly.... Bit like the replacement exhaust hangers they used to sell :-(
