Wheels will not come off -.-
I have just bought myself a 6n 1.9D and went to go fit coilover to it today.......
took wheel bolts off drivers side front and the wheel WILL NOT come off, have tried kicking it, pulling it, even hit it with a hammer :')
sprayed shit loads of WD40 on it too!!
it won't budge
any tips??
  • Replies 26
  • Views 4.4k
it won't budge
any tips??
you sprayed wd40 on it?!?! good luck stopping!!! hahaha
Was nice knowing you :)
Seriously though not got a clue :/ apart from getting under it and using a hammer from behind :/
leave the wheels without bolts on, then lower the can back down SLOWLY, the weight of the car should loosen the wheel off.
Drive it with no wheel bolts and wait for it to drop off.
Sock knopws the score!
it won't budge
any tips??
was only one side, i have other break..........
lol
i tried this too!!
and hitting it from behind
dont do this....
Dont tap it, Whack IT!
me and mates have all whacked the f**k out of it lol
Nice innuendo there, well spotted and well timed.
As for the wheel, use a bigger hammer. If it's not falling off the jack/axle stand you're not being violent enough.
Russian screwdriver!
Nah just put the bolts in a few turns, lower the car down and drive slowly backwards and forwards for a bit ;)
put the wheel bolts back in, don't do them tight but just so the wheel won't come off. drive it up an down the road, try again.
If that fails, hit it harder with a bigger hammer :-)
And when it starts making a weird clunky sort of sound you know its come loose!
You're not wrong :lol:
had to do it on my old car a few times
Remove wheel bolts, lower back down then do the biggest burnout you can muster.
Make sure you have a friend filming from a safe distance
Happened in my mates car.
We were like "whats that noise"
"fuuuuuuuuuccccckkkkkkkkk" :lol:
wedge a plank across the back of the wheel and jack it between the plank and some part of the 6n thats not rotten away
aha cheers for the advice guys, will have a go tomorrow :)
its a steel wheel
Spraying wd40 won't do much harm to your brakes. You'll burn it off in seconds.
As said, you just need to smack it. Or if the wheel has holes in it, then try and get a lever in there
6n?
Scrap it, the yards always give the wheels back.
yeh just drove it, brakes were fine :)
yeh ill try levering it aswell!
as for the 6n comment from yeti...........i like 6n's sorry? lol
man up.lol.get a car jack in behind it
I have tried loosening and ragging it round corners but still won't budge :(
that is a quality idea!!
