Rear Screen Wash Jet/Pump
Not working, is it may be the fuse? Think I did check, what else could it be?
  • Replies 8
  • Views 1.2k
Does it sound like you can hear a motor running when you activate the pump?
mine wasn't working when i bought my mk2, took me ages to figure out what it was....... there was a nice big puddle of washer fluid on the floor under the car where i'd been activating it, turns out a pipe had been disconnected.
If it was a fuse youd probably find a couple of other things in the car not working as well.
Check the pipe like suggested and listen for the motor.
Thats all the advice I can give.
Possibly a blockage in the pipes too but i dont think thats likely.
I had that problem, just the pipe disconnected from the washer tank for me.
i got the same problem but whoever had it before me has bloody cut the pipe in half :angry: so if anyone knows where i an get some of the pipin or something equivilant?
halfords do it with the little connector last time i checked
sound, cheers bud!
Thanks guys, yeah no motor running...VW garage going to look at it but think I will DIY! They charge arpund £70+VAT these days!
what model do you have? as most use the same pump for front & rear screens, so if it's OK on the front it won't be the pump, more likely to be the switch.
