Fuel pump 6n 1.4 8v
I'm changing my fuel pump on my 6n 1.4 8v
I have all the pipes out and the pump hanging out, all that needs to come out is the plug from the wiring loom, but I carnt see how the plug comes off though I'm not sure where to push :/.
Anyone know how to get the plug off? I'm stuck on the last herdle lol
Help!!!!
  • Views 387
I can't remember if it is one of those with a spring clip on the outside, if it is, you need to remove that clip before the plug will pull out. I seem to remember that there are two lugs on the plug which you will need to squeeze between your finger and thumb as you withdraw the plug.
Regards.
