What a job!
Gave my Gti a service yesterday,what a job to get the oil filter off,took me bloody ages to get it undone then could'nt get it out!!!! Spent a couple of hours changing oil/filter etc,could have removed my entire bus engine & put it back in twice in that time! Modern cars,improvement mm yeah.
  • Replies 24
  • Views 1.4k
i tend to loose my rag pretty quick with oil filters if they dont come off streight away, i like the old bang a screwdriver through it and turn method lol, always works but is a bit of a bummer when you realise youve been sent the wrong filter ha ha
Undo it from underneath the car and it comes out easily. :)
I didn't have a problem with mine kev.
you got large hands or something?
last none i did was done by hand - got covered in oil though....
lol, i had tome right joy with the last one i changed, on a GTI block too.
Bent 2 screwdrivers, had to wack a pry bar through to get it off :lol:
thats why there is a nut on the big 30mm nut on the bottom of the filter so you can use a spanner on it!
simples
Oil filter pliers - cost about £8 a pair and are well worth it.
Thats just because your weak as shit - got nothing to do with the filter being tight :lol:
Take it no one here has tried doing it on a passat b5 20v N/A :lol:
top tip!!!!!!!!!!!!
my dad is a mechanic he always puts oil or grease around the o'ring of the filter never has a problem taking them of next time and in case your wondering no they dont leak or fall off lol better off using a strap rather than any other of the tools
I was alwYs told they should only go on hand tight anyway. They shouldn't get THAT tight then
ye. spin on till they start to grip, then slight sharp twist by hand.
but the o-ring expands and tightened the buggers on :lol:
top tip!!!!!!!!!!!!
this.
never had a problem, bit of oil on the o ring and hand tight... always come off easy. if they're too tight something been done wrong ;)
also if you're changing oil when warm (which you should always do) it is easier to undo as well.
No they should only be hand tight,this is the first time I've done my polo since owning it,previous person must have tighten it up!! I always put oil around the seal when putting new one back on,tried the 30mm spanner would'nt budge at all ! From above or underneath,went for the screwdriver method in the end :badgrin: Once undone there was hardly enough clearance to squeeze it out passed the radiator pipes,hopefully next time it'll be easier now i know what to expect!
You know its tight when the 30mm nut at the end rips off, iv always used a chain strap after this and it hasnt failed me once.
Simply strike the side of the filter until it bends, then do the same the other side (from top then from below, or vice versa). This stretches the thread plate of the filter and removes it's clamping torque from the block. Then it turns far more easily.
off topic but yeah
helped my dad out last night doin track rod ends on an audi a4 (he doesnt do many cars mainly vans/lorries/plamt) the wheels were so tight after some brilliant tyre fitter we had to use the bar he has for undoing lorry wheels thats about 5ft long and once craking them tried to spin them off with the cordless snapon gun and that would take them off on its own
i dont understand why some people insist on overtighting everthing
Better than too loose, I was filling the van up about 2 weeks after having had a tyre fitted when I happened to look down at the back left wheel and noticed a wheel nut wasn't even touching the rim. I found I could undo 3 out of 6 wheel nuts with my fingers... bearing in mind my van spends a lot of time on the motorway loaded up, coulda been nasty :paranoid:
i know where your coming from but its a woman driving it most of the time and what chance will she stand if she gets a flat tyre and tbf even it was butch woman or a man they wouldnt have undone them with the kit in car so would have cost a £100 min if they were to get a flat
i second this! never had a problem since i bought a set :)
I use filter pliers as well. I wouldn't go hitting the sides of the filter with a mallet or something, could get even worse when you snap the stud that holds the filter on in the block!
If i was weak, the screwdrivers wouldnt have bent would they :lol:
And as for the big fucker on the end... nothing would fit properly, just rounded off.
..which is stronger than the pressed steel filter plate.
You've snapped one, i take it..? Well i haven't, and it's worked for me and others i've known for hundreds of times over many years.
I got a set of stillies on my oil filter on my old rover, works a treat :) lol
