Mk2f seat replacement upgrade
Hi, I'm just wondering what seats fit directly into a mk2f
I've been searching but I've found nothing, I would like front and rear replacements, I know the front of corrado fit
But not sure about the rear
So if any has fitted both front and rear into there's let me know what your running?
  • Views 4.9k
Mk2 Scirocco seats fit perfectly, front and rear. I've got them in my 2F and the are a direct fit, even the rear bench.
Scirocco GT11 fronts and Polo Genesis rears ;)
front seats:
mk1 and 2 golf
mk1, 2 and 3 polo
rocco and rado
as for rears, as above the scirocco gt2 seats match the genesis material, so they look the part.
However if the rocco rear bench is a direct fit, i don't see why golf benches would be hard to fit.
apparantly the later subframed front seats can be made to fit with either a vice or a hammer, so that then opens up polo 6n, polo 6n2, mk3 golf etc.
However i can imagine the rears being wider.
i'm running mk2 coupe s seats with mk3 doorcards in my mk3, so all direct fit.
Edited by VolksKid83
front seats:
mk1 and 2 golf
mk1, 2 and 3 polo
rocco and rado
Sweet info cheers, I don't know what to go for I just want tidy modern look, i would like Ibiza 16v leathers front and rear, I've thought about swapping the matierial and sponge but I think I'll have to swap the bulster matel bars too
well the fronts can be made to fit, the two runners at the back are slightly further apart than the mk3 so its a case of reducing this width, like i said people have used a vice or a hammer, however my personal method would be to cut a slot with an angle grinder, bend to the correct width, then fill the slot with weld.
As for the rears, i can imagine them being wider, i.e. they wont fit in the space of the mk3. I also know that they use a different method of latching the backrest.
I can see this being the hardest part, probably here your best bet would be to make the seat material and foam fit a the polo seat frame/structure.
