Breaking 1.3 engine
Have an engine in my garage. Anyone want anything. For sake of needing to, I'l say every item £10. Add requests and offers on here
  • Replies 14
  • Views 324
what engine is it? aav?
nice1
Yeah what engine, got the dizzy?
Sorry. Its a mark 2. So HK (?)
No dizzy. Its just the block, head and manifolds. No electrical ancillaries or carb
oh, and oil pump and sump have gone!
If anyone wants the whole thing for a 10er, its yours!
can you sell just the head ? would take the hole lot but abit to far to go =// cheers
I would, but I'm guessing you want it posting?
why has the sump and pump gone???
if someone was going to pick this up its going to be messy
was interested but with bottom end stripped not too sure now
pmd
Pump and sump was used in my 1.6 conversion as I needed a shallower one
Pms to be replied to
Does the rocker cover have 3 studs down the middle or a load round the outside?
Which one are you looking for? The one I have on it ATM is a 3 stud one, but it has a seat badge on (was swapped at some point :? ).
gearbox?
Holding on to it I'm afraid
HK with a hydro head?????
mix match engine dude
HK is low pressure and hydro is a high pressure head
is this why its no longer 1 piece?
what kind of inlet has it got?
Maybe not an hk then (hence the ? after the identification above) could be hh. I'll have a look next time I'm up the garage
Anyhow, had an inlet for a pierburg on it.
It hasnt broken at all, just didn't want to scrap a good engine with the car. The head could probably do with a skim as it's leaking in the usual spots
