Black 6n 1.4 16v
Have got my little Polo valver which I think it may be time to get rid of...
Have had the car for 3 years but it has been on and off the road for the past 1 and a half. The body is on 90k and the engine 70k, although the reason it first went off the road is due to the current lump running on only 2.5 cylinders. I replaced the engine a couple of years back after getting stuck in flash-floods and I have a feeling it now needs another new heart!
Would rather see it go as a whole for 300 quid as the shell is pretty good and would make a good starting point for an engine swap project. It still drives although has obviously not moved in a while...
Good points
Gearbox was always okay up until I stopped using her
Nice 14" 4x100 G60 steel lookalikes. Made by VW and with four good tyres
Interior is tidy, usual bolster wear on drivers side seat but rest of the areas and trim are all intact
All arches were professionally rolled and the rears flared. Had a wide set of BBS (8.5", et0 at the back) and they were fine without people in the rear
Very little, if no rust that I have seen. Under the arches is all good- slight paint cracking on one of the rear arches from the flare
Bumpers are in good nick- few stone chips n marks but prime for a respray
Bad points
Engine needs work- either the headgasket or something a little more serious, I haven't been using the car or had time to get it looked into
Bodywork has a few dings- standard shopping trolley crease in drivers door and a little one that could be popped out of the n/s wing, stone chips in bonnet
Exhaust from the cat back is pretty loose from speed bump run ins
On coilovers that haven't been raised/lowered in a while or greased- could always take em off and have a look though if someone wanted a cheap set
As I said, I'd rather see it go as a whole but if nothing happens within the week I'll start taking it apart.
List of the more general parts is below, specifics PM me with a request and an offer. Will post all the smaller bits n pieces but nothing outrageous.
Gearbox- 150
Door cards- 30
Seats- 60
Boot- 40
Wheels w/tyres - 120
Bumpers (each, no splitter)- 30
Front wings- 20 (each)
Headlights/ taillights- 30 (per set)
Located half hour from Milton Keynes
Pictures to follow....
  • Replies 45
  • Views 2.2k
any fogs fella? if so dibs on the fogs loom and switch pleasee
How much for gearbox posted?
Once you get pics up mate, might be interested in both bumpers can collect to.
sorry no fogs- took the grilles out to replace them but the set i bought never turned up!
will look into how much a gearbox costs to post and get them pics up soon as
How much for coileys if you can get them in working order?
Bought some other day but seized to fuck so just cutting my losses :/
how she stands at the moment:
front bumper is missing lower side grilles, towing eye and the splitter will be coming off as well...
the mark on the rear bumper is a scratch not a crack
not sure how much for the coilovers mate- will have to see how they look when i get em off sorry!
Evening mate
How much do you want for the bonnet collected from MK, can swap mine over if you need one on it. Also how much fro the grille surround.
Steve
how much for the head bud?
how much for the rear wiper blank posted mate?
cheers
Number plate lights posted?
U bracket on the nearside power steering rack (the clamps that secures the rack to the subframe)
I'd take the coilovers
you still got the 16v manifold?? pm me.
i will take both bumpers front and back for 60 pm me if interested!!!
how much for the backlights??
How much for the passenger side electric window mechanism mate?
Clear side reps posted, how much?
how much for fuel pump?wich year is polo?
how much for both wing mirrors if they are mint and electric
Are the wheels Audi pepper pots? and what size are they? and what size are the tyres? cheers
Hi i am looking for a throttle body 036 133 064 E. It should have the same one as i have the same engine. was wondering if you can help me out. thanks
how much for coilovers posted if the can still be adjusted??
hi how much for the gearbox and anyway of posted
gearbox ??
