Plastic Door pillar bits....
What holds the black door pillar trim on?
I can see 2 screws at the top where the grab handles screw into but is there anything else holding them on?
  • Views 780
Inside or out?
Inside or out?
its gotta be inside due to the grab handle.
I would have thought that once the seatbelt, grab handle and interior panel are removed its probably stuck on, so a case of gently pulling?
It may go behind the door and window seal too
Thanks guys, I thought the same but didnt want to force it in case they broke, been too busy today rewiring the caravan my rents purchased.
Epic electrical fuckups by previous owners (not the ones we got it off, they didnt have a clue about caravans or a car to tow it had they plugged it in the consequences could have been pretty bad). Couldnt work out why the radio had a blown fuse, traced the wire and found the 12v radio had a 240v plug fitted on to it.......AND it was plugged in.....
So tomorrows job is attempt to get the plastic parts off my car.
