Don't get caught out....
make sure you have suffient coolant and % for the upcoming cold weather
check tyres / pressures
top up screen wash
check wipers
get your scrapers and de icer out of the shed
remember to not hit the down button on the windows whe frozen - the plastic clips don't like it
feel free to add any other things worth doing pre snow / freezing weather
Olly
  • Replies 60
  • Views 6.5k
Set of wellies in the boot!
incar phone charger
one of them tinfoil heat jackets... or a blanket
a big fluorescent pole to gig into the snow so you can find your car when you come back for it and its been
snowed over :p (not even joking, mum lost her car for like an hour last year there was that many cars ditched in teh snow hahaha)
spade.
Oh n I'm sure a small camping stove and a tin of beans wouldnt go a miss, you never know, specially if you have to drive country roads :p
Don't use your wipers to clear the ice off your windscreen..
Edited by R0yaL3
Don't use your wipers to clear your windscreen
Or a kettle!
anybody who does that is just begging for autoglass to come rip them off when they crack it :p
Folding shovel, Tow Rope, Torch, Warning Triangle, Hi-Vis Coat.
Olly, you're my hero.
Wtf?
Winter tyres help a lot.
Bag of grit helps too
Common sense.
Common sense is the best tool in the bad conditions.
Along with that I'd have:
Warm jacket
Hi-viz vest
Spare car mats
Spade
A few litres of water
De-Icer and scraper
And finally good winter tyres.
Warm jacket
Hi-viz vest
Spare car mats
Spade
De-Icer and scraper
That failed last year. needed it to help someone and had a 5l Ice cube. :lol:
Or a kettle!
Yeah kettle is over kill, warm tap water is perfect but use the wipers to make sure its well removed or you risk refreezing before your heaters take effect
Or a kettle!
i disagree, a kettle is a life saver when your locks freeze up!
but hopefully it wont come to this as you have put some form of grease/lube in there already ;)
Warm jacket
Hi-viz vest
Spare car mats
Spade
De-Icer and scraper
But antifreeze in it... oh...wait...
^^^yep, :lol:
I do have a second 5l bottle of 50/50 mix for coolant.
spare set of rubber mats, came in useful last year after getting stuck in a carpark, slipped one under each front wheel and it done the trick :thumbsup:
Now let me think. When it snows: Sofa, T.V, and the heating all the way up. Bugger going out!
Not harassing your locks when they are quite clearly frozen.
problem with pouring water over your windscreen is it either freezing back up even worse on your windscreen, or it freezing on the road and causing a crash...
I've got a heated window scraper waiting to go in the car.
^^^ Jump leads when your heated scraper drains the battery. :lol:
Already got a set in the boot :lol:.
cup hands round frozen lock and breathe out into the lock a few times to clear.
