Polo Variant Pick-up?
was having a little look though google as variants and saw this beauty, its been Photoshopped and looks great but do you think it would actually be possible to build this for real and if so what would be the legality of it??
Before
After
  • Replies 17
  • Views 5.4k
skoda do one similar
thats a skoda tho....... polo ftw
PLUS that variant looks a lot better
Edited by pascoe92
i know, i know, just letting you know :) does look nice tho
i just wanna know if its possible and the legality and u might see it for real
whats the point, will be identical to the newer shape caddy...?
front end, bumpers etc are all the same
http://farm4.static.flickr.com/3004/259077..._1cdd8474d1.jpg
d.
comparing the two the photoshopped one looks nicer
Yea I didn't pick the best google image, diff bumper etc on that one. The main thing I can think of is that you won't get the same response as another car converted as I think peeps will jus look at it and think, nice caddy.
Looks sweet don't get me wrong but a lot of work when vw have already made you one.
d.
It's not actually a skoda, its a vw caddy... Or visa versa
If you were going to do this tho you would be better off starting with a caddy van rather than a polo estate. It would already have the bed flooring in the back and would be in better proportions imo and looks more polo'ish than the caddy pickup
the mk2 vw caddy pick-up is a skoda. its based on the skoda felicia/favorit chasis and has feck all polo related parts on it. The only thing remotely vw in them are the steering wheels on some models and the engines if you go for the 1.6 petrol or the 1.9 derv.
Just looks like this... :lol:
28365_446903950328_582110328_6074520_274
28365_446903935328_582110328_6074518_530
good idea with the caddy van guy but does anyone know the legality of cutting the back off a variant estate or caddy van ??
as far as I'm aware you have to declaire it to dvla, but a dont think you need to take them for a vic check, even if you do its only to check that the vehicle is what you say it is and theyl check your vin number ect, have seen loads of estates cut down into pick ups so its definately do able if you wanted to, just depends how skilled you are or how deep your pockets are
A polo saloon/estate shares nothing with the polo either. Same base as the caddy van/pickup. Why not turn the saloon into an estate, vw have already done that too.
d.
There used to be some massive legality's that meant it was virtually impossible to legally register a converted pickup. Iirc this has been addressed now but its far from a case of just having a vic check done. You have to be able to give a full detailed photographic report of the build plus the car has to go for a inspection to check that it is safe to be on the road (just chopping the rear part of the car off and plating up the gap behind the front seats won't cut it) and the car will almost certainly be given a Q plate if it passes the test.
Any car with a chassis modified along these lines (pickups, convertible's, 'limos', ect) that ain't wearing a Q plate probably haven't been registered and anyone thinking of buying one should be aware that the dvla will remove the registration of the car if it comes to light that the car is being used
what does the Q plate mean guy ?? and i was planning on doing it properly if i was to do it at all
The Caddy pick-up is a Skoda Felicia and is blatantly a completely different shape.
The Caddy van is probably the best donor vehicle for the proposal, then the rear quarter panels from the estate.
I remember a 2dr 306 Sedan being built, they did a great job, but many fail at welding rear doors up - only use the outer skins, don't actually leave the bloody door in place!
i was thinking t45 frame to create the bed and roll bar behind front seats and then box everything up so that the structure would be strong but make it so that it looked original
