cylinder head
hi all I'm after a head for a 1.9 diesel polo mk4 for a fellow vdubber let me know what you got cheers carl 07876031652
  • Replies 9
  • Views 639
i might have one around mid december dude, i have one of a td, but i may have a full aey coming in with a shot bottom end.
no problem no rush its for someone else who has to strip his engine first but its a non turbo one if any different cheers for reply
It will be aef engine code mate I've got a full good running engine still in the car yours for 150 I think the aey sdi engine is from the 6n2
cheers mate thought it was aef engine i just took mine out for him butlooking at putting it in a type 25 i just got so hes just after a head but il put engine to him see what he says do these engines have an ecu also as i scrapped the car without checking and if so how much for loom an ecu cheers again
Are you after the engine loom or the whole wirring loom ?
basically just so the engine will run will be able to use my starter cables etc not really done it before just good at taking them to bits dont suppose you know anyone whoes clued up on bits il need
I do indeed his name is Ben runs south Manchester aircooled works in the unit behind the one I work in does type 2 , 25 & bugs pretty much all aircooled Will try get his number Tommorow for you
ah think my mate tyler paul wi splitty knows him cheers mate would be a big help
You hava the pm'a !
