Mk3 clocks
How can I remove them without having the little tools? Basically I have a bulb out on the left side. What bulbs are they by the way so I can get one before I remove the clocks (save me having to take them out twice)
Edited by aroncmc22
  • Replies 8
  • Views 1k
There's an FAQ on this, use the search next time
Can't remember what the bulbs are, but if you haven't got the tools to remove the clocks, pull the stereo out and the drivers side dash speaker and you can get to the clips on the side with a screwdriver. Push them in and pull the clocks forward, then rotate them so you can pull them straight out through the steering wheel.
I'm not a noob to this forum, the faq is for mk4's
A noob? You have over 3000 posts lol!
Have you tried tapping/knocking the clocks to see if the light comes back on?
yeah tried that dude. not common for the bulbs to go then i'm guessing?
use an old credit card,how i got mine out :p, slide it in down one side n push it under the clips and pull the one side out and the otherside should just come out :)
