Painting wing mirror trim 6n2
just wondering how it can be done
would you need to sand down, prime then paint? if so, how many coats?
here is the inspiration pic and what i am talking about
thanks for your help
Edited by woolley456
  • Views 956
anyone?
you could post a question in Karin's thread asking her? I'm sure it was sand down,degrease. prime and spray once or twice.
cheers matey :thumbsup::nod:
you will need to sand down (use fine sand paper as coarse will scratch into the plastic and you will see them under the paint), use 1-2 coats of special plastic primer, 2-3 coats of paint, and 1-2 coats of Lacquer if youre wanting the same finish as the picture
Edited by michael6n2gti
my usual way at work is to use a solvent based degreaser with a red scotch brite to get a good key to the plastic, i always feel this is better that sand papper as it doesnt score the plastic too much and also the degreaser helps get rid of any silicon based sheens that may have been used on it, next once its cleaned and dried off you need to apply a good coat of plastic primer, try just a light coat at first then once its flashed off put a nice covering coat on, leave this to dry the lightly with another red scotch key up the plastic primer, then apply a good 3coats of high build primer. once the high build is totaly dry you can flat it back to a nice smooth finish (some body shops are different and may either wet flat it or dry flat it) if dry flatting use a 400-500 grade paper, if wet flatting use an 800grade wet flat paper. once its all flatted, degrease and dry again and ensure its totaly clean before painting. i cant tell you how many coats of paint it will need as that would depend on what sort of paint you are using and what colour and again depending on what paint you may not need to laquer. hope this has helped and give me a pm if you get stuck
