rate or slate exhaust manifold
  • Replies 26
  • Views 2.1k
I have a hot tuning one on my 6n 8v didn't do much performance or sound wise, did make it abit better top end tho!
I wouldn't look too far into the claims of big power increases, the tubing is a bit big so whilst it may free up top end, you might even loose a little torque at low revs.
However, 45mm is bang-on for centre section size if you're looking at at least 80 brake, it does look nicely made, and unless it's made of foil it's a steal at that price!
tempted by one of these myself. As Mikey says, as long as its not made out of cheese wrapped in tin foil, its cheap as chips.
someone i knew bought the cheapy one from germany, it was good in the end, however had a couple of problems fitting it.
Firstly there was no nut for the lambda sensor, however only relevent if you're fitting to a mk3.
Secondly it was a bit out of shape, therefore they had to bend it open a bit to fit, but once fitted it was good.
Don't you need the nylon G40 arb blocks to fit these?
Can rub on the ARB so G-lader/PPP poly ARB blocks give the clearance you need as it moves the position of the ARB slightly.
I have had two of these in the past and they are fine for non G40 use. On a G40 they foul on the charger/charger bracket iirc.
Suprisingly these aren't made in China, and they are £125 delivered through the forum... ;)
you dont need arb blocks.
you aren't lowered then, my mate is 60mm down on his gt and he couldn't put the arb back on after spending ages fitting the manifold, you do need them if you are lowered
ahem lowered quite abit sir. had plenty of room, even managed to get the manifold on/off without taking the arb off, just needs alot of wiggling!
i was 80+ mm down on my old gt with a 4 branch and no arb blocks....
then why couldnt my friend fit his?
maybe his has had a crash or somethings done up wrong/not in place properly. could happen!
i need the blocks to fit mine! about 2 inches out re fitting arb :(
I'm not running them on my afh conversion either :ninja:
Dont ask me, I'm just telling you what mine had :lol:
Youl struggle with an afh, my arb was wedged on the 4 branch with arb blocks :lol:
its already in mate! lol
you got a subframe or something or have you just generally chopped the chassis up....
who?
Why would you need to chop the chassis up? :?
hahaha i dont know move the front stuts forwards or something but i was kidding, but when i was there with my mate fitting the manifold from philj off ebay there was no way that the roll bar was going back on, it was about 2" from going on and then it would be touching the manifold, but him and his dad did reshell the car into this one
sounds a bit dodgy that.. my old 4 branch i had on my 1.3 cleared mine with plenty of room to spare, and i bought it off a mate who also had it on his without it touching. both of them we were able to remove and fit it without removing the arb. so thats a bit wierd! should get it checked out tbh mate!
Yeah iv known a few with them on aswell which have been fine :?
Eric mine was a proper squeeze with arb blocks on, was a mk3 though but that makes no difference :lol:
i didnt think i would get any replys so nt looked on this post for a while. gd to hear positive feed back i wasnt sure but i like the fact its all good. when the moneies right il certianly know were to come
really?! thats well wierd! i dont think theres any design changes on the arb or anything though are there? thats crazy. youd be buggerd trying to fit an afh then!
