29 year old car - First patch's of rust!
Today i had a good look around the extremely faded paint work of my little bready. Paints started to bubble so i think the rust is hiding down under. Only 4 areas so its all right and tiny little amounts.
ANYWAY! going to get them treated but I'm quite proud its lasted this long. Its no show winner of any sorts so was thinking of painting over the rust patch's after they have been treated in a contrasting colour to the body work.
I think it would look quite good but what do you lot think??
The bubbling is on the very front of the wings, around the headlamps. And the both the bottom rear wings below the level of the rear lights(Just above the bumper).
  • Replies 14
  • Views 1.2k
I think if its lasted 29years and your happy with the car you should treat it to a respray! I know I would!
Basically its lived 29 years nice and strong but seems to me living so long with faded paint its giving up the ghost, so maybe a little respray, a nice clean on the interior and sh'ell go another 29
they're like girls, they just need a little treat from time to time in return for all the pleasure they give ;)
This is how mine restoration started...just a little bit of rust.. now its sitting in the body shop on crates ready for new paint to go on top, bottom, in and out! :)
I've got a feeling mine will end up in a full restoration if i end up re-spraying it.
if you dont have funds/time to do it now, just treat them and prevent them from getting worse then when you do have time/funds, do a proper restoration, a wise wizard once told me do it once, do it properly :)
Edited by Gamu
mine was.. 'well I've gone this far so I might as well continue!' and a bit of the 'While its off, I might as well...' school of though :lol:
Totally the same as you mark. Originally I was going to leave the paint work alone bar a polish. But the standard and amount of work I've put in, it has to have a respray :?
29 years ago they were using exceptionally good metal. The areas you speak of are high aggitation points of abrasively dirty air, so it is most likely the corrosion resistance is failing.
This is a perfect example of a shell that deserves to be re-protected, because it'll thank you for many years to come.
But a cheap blowover will do nothing to help, it needs to be done properly. Justifying the cost gets easy when you see how much it'll cost to buy/run other cars instead, plus the fact that these cars - as with others like it - are appreciating in value.
Its quite scary just thinking about the cost of these things. The cost of transporting to a specialist it will be more than i paid for the car itself, yet I'm thinking hard about getting it done.
I know that mk2 polo's will never have the following/value a mk1 golf of the same year would have. Especially mine as its been slightly brought up to date so has lost most of its originality.
How much you reckon it will set me back to have it fully dipped, patched and spayed?
My Derby is 30 years old this year, where it's solid it's bloody solid but the rot is just totally gone. I wouldn't like to give you an estimate on welding and paint. Keep it original as you can though, dude!
It depends what it actually needs. Early Mk2 Polo's are probably some of the best rustproofed cars I've ever seen. If it's localised areas, I'd have my reservations about stripping the whole car on the grounds that what you replace the existing reustproofing with may well not be as good as what VW used in the first place.
Mikey :thumbsup:
Edited by brightsideteeem
well you are looking at 700ish for the initial dip and then 700 for the zinc primer. You then need do do the repairs which if you do them your self a couple hundred or and if the car is already stripped then about 700-1500 for the respray and then all the new parts you need to put it back together.
It makes no financial sense what so ever as the car will never make that money back for you (definitely not in the short time anyway).... but it hasn't stopped me.
I'll never sell my polo and it will be coming back to the US with me so for me it was worth spending the money and I know that I'll have something special and will last a good few years more! :) I didn't go for the strip and dip even though I was tempted to as it does mean a load more work and a load more product to be put back on the car.
How mine currently looks (but with out the rear axle and windscreen)
Should be in primer this week 8-)
I think ill treat the areas that need to be done and then respray.
I dont have 1k to spend on anything right now so i think ill keep it running for a while and save some pennys! :)
Keep it trundeling along for a while :D save up for a spray job/TLC next summer! :)
