boot lifters
This may be a stupid question but, I was wondering if you could get stronger boot lifters for my mk4 polo. I have a smooth boot and a popper, so its annoying when I have to grab the edge of the boot to open it, I want my boot to open all the way when I press the button.
They would have to be very strong to overcome the leverage produced by the boot. In fact I'm not sure that would work. You need to get the boot above a certain point before the lifters begin to lift. Ideally you need a strong popper so it actually lifts the boot lid above the point required to open it. Or hefty springs under pressure to pop the boot up when they relieved of the tension
ah right, thanks for the info :)
you can make then stronger yourself, take them off and put small springs on them and when you pop the boot the spring will expand and forced them open and push the boot up, done it with a mk5 golf gti that we smoothed the tailgate on
were could I mount the springs though?
On the lift itselft
On the lift itselft
right cheers, ill give it ago on the weekend :)
