BEST ENGINE OIL FOR A POLO 6N2 GTI
Hi guys,
just want to give my lnew little POLO GTI a service.
Its a 2000 plate.
Whats the best engine oil to use for the service?????
any recommendations?
  • Views 11.2k
5w40 semi synthetic is what millers oils recommend, and what i use in mine. :thumbsup:
how much for 4 litres of that mate?
they sell it at around £35 for 5 litres, id rather buy 5 litres anyway as the whole system takes up 4.5 litres from completely empty and then youve got half a litre to top up with if required. i know its a little expensive but as a mechanic i see the result of internal engine wear due to poor oils quite a lot and its quite a false economy.
^^ Fuck that, you want fully synth 5w/40 (semi should be 10w/40) and you can get four litres of SM rated stuff (semi only goes to SL) for less than 25 quid - there's no point getting more than 4 litres because your car only takes 3.6.
I get SM rated fully synth at 5.50 a litre, don't pay for over marketed labels. And don't run semi synth, which is actually a mineral oil. Fully synth will prolong the life of the vvt system over minerals.
indeed its 3.6 litres. I have a 1.4 16v and its of similar architecture to the 1.6 16v gti.
