Mk2f bonnet on Mk2
Since the gothwagen is in the garage with the front end in bits and I've made a start modifying the front end properly, thoughts turn to other things I might be able to do. Namely, the thing I'm asking about here is fitting a Mk2F bonnet to a Mk2 without changing the wings.
I suspect the following will mean it won't work:
- leading edge will be too low or too high to line up with the Mk2 wing leading edges, giving an ugly step.
- trailing edge of the Mk2f bonnet won't line up with anything on the Mk2 wings and just look nasty.
- Mk2f bonnet will be too wide/narrow long/short or just incorrectly curved to fit between the Mk2 wings.
If you're curious, car looks like this and needs lots of things making, finishing and putting back on, including the now modified (passenger side) Type 3 4 Variant headlight brackets which will be getting an upgrade to H4s.
Edited by Angyl
  • Views 2k
I think you've pretty much answered your own questions really :roll:
Type 3 Variant headlights? They look more like Type 4 to me :?
(The Type 3 had single headlights same as the late 60's Beetle, the 411/412 cars had the twins)
what i was thinking.
To add to the list, the mk3 front panel sits further forwards than the mk2, therefore the bonnet catch etc would be too far back on a mk2, the bonnet should be longer too.
Personally i think its a case of modding a mk2 bonnet to your desired specification, atleast it will fit in the first place!
You're right, it is Type 4, like this. Had convinced myself that was a Type 3 for some reason.
1971%20Volkswagen%20VW%20Type%204%20411%
Thanks for confirming what I already thought, good to have a second opinion as it saves me wasting money on body panels I don't need.
I love the look of the Mk1 Golf/Mk1 Polo front end, and simply think that the lowest edge of the mk2 Polo bonnet line is unnecessary and odd looking.
I'm going to cut the very edge of the lip of the bonnet off and very carefully weld it. It would be far easier if it wasn't dual skinned but however it needs to be done, it'll get done. It will be my brother who does the welding.
Do you simply want a straight edge to the bonnet, like myself?
I am very surprised no-one appears to have done this before; the bonnet edge looks exceedingly ugly to my eyes! I thought that a Polo Classic bonnet might fit but I don't think they do and they lose the lovely bonnet swage lines anyway.
I'm going to repost about it, as this is turning into a thread-jack!
