Gun Metal GT 16v
Looks good buddy. And yours has changed a little bit... It's now infront the garage waiting to remove and fit its New engine. Iv had to put off the project as Not Only a lead but got a grass tracker too so money's tight. But it will get done ... Eventually. Looks Good tho buddy. Keep up good work. Drop me a text if u need any help with any info.
Cant wait to see it back on the road! Hopefully some shows next year if you pull your finger out! Ha moneys tight for me to at the moment specially with xmas! And i wanna go thailand next year for a month so the car may have to wait
  • Replies 76
  • Views 9.3k
Took the 8p box off the gt lump today image-31.jpg.
I have taken the clutch off to just got the flywheel to remove image-32.jpg.
image-33.jpg.
Basically got a load of cleaning and painting to do before it gets put back together
i said that too (the cleaning and painting bit) but patience isnt my strong point lol. regretting it now!
same dude! But really wanna make sure everything is spot on! What bolts did you use to hold the fly wheel on are the AFH and mk3 stretch bolts to short? Also i could be a massive bellend the mk2 vaccum dizzy the rotor arm doesnt continuously spin only does like 180 and then stops and i can spin it back the oppsite direction 180 is this normal?
Edited by p0Low
I'm running the mk4 flywheel bro!
my dizzy did that when i took the vaccum advance off then put it back on when i was bored. one of the screws were too long so it stuck out and the rotor arm got stuck on it!
You saying that i did take some of the bolts out when i started to polish it up i must of put them back in the wrong place
yeah probably the wrong way around or lost a washer or something (if there were any)
I got some pics sent over from 2006ish before she was abused!!
image-34.jpg.
Not much of a update just cleaning, sanding, painting, repeating :-/
White primer image-38.jpg.
image-39.jpg.
Edited by p0Low
image-41.jpg the colour the engine bay is going pictures dont do the colour any justice its still wet and needs lacquer but hopfully looks good!
Brilliant work Jake! That U-pol etch stuff is great isn't it! :lol:8-)
Edited by Phataz1
thanks bud i still need you to make my manifold or my car is
never going to see the road!!! I will have send my carbs once i get some more money Yer etch stuff is great always worth useing!
image-43.jpg.
image-42.jpg.
Fresh! All done and ready to go on still got the top gearbox mount to do and the rest :-/ happy with the out come as this is the chosen colour of the engine bay
Alright! Cheers for the wheels earlier mate! Build thread looks good ile be keeping my eyes on it!
Stripped the front end and found this today cars full of surprises!!
image-44.jpg.
I knew it would have to be replaced as this
image-45.jpg.
Iv been sorting out hideing the wiring today (LONG!!!) I'm not sure what i can 100% remove so i may have to cut out whats not needed once engine is in and running
what the fuck did he do to it, when i sold it it has a slight bend in the lower slam panel that runs under the lights. looks like its been hit with the engine when it was taken out for a rebuild !!
Looks to of been towed by the slam panel?!?!?!
Sorry pal your banned from my thread as everytime i see my number plate i think jizz cake!! Ha i have no idea it wouldnt surprise me!!! Its a shit part to have to change to! And gonna be a pain to get hold of one previouse owner said the top part was smashed with a hammer a few times dont no why :-/
Edited by p0Low
they are not hard to get hold of and not to hard to get out, you need a spot weld drill bit and a decent drill. thats about it really. i replaced one on my first polo GT back when i was 17 took me a weekend to get it done. take the wings off the front bunper all the lights and wires that run through it then just drill the spots. place the replacement in and puddle weld it in. just make sure at all times u have measured and clamped it in place before welding. just make sure u get the ident plate of the old one which i forgot lol
Thanks bud I'm not really to worried about fitting it just removing it but sounds simple by what your saying! I'm finding it hard to get one as no one will remove it from cars they are breaking kinda lame :-/ hopefully be a straight forward job i will spray it my self as you only see a tiny bit. Thanks for the help
I need to replace my front panel too! not quite as bad as yours but keep us updated on how it goes :)
Thought i would do a little update nothing has really happend exciting pretty sure no one cares lol but anyway i have sprayed all the mounts now
image-49.jpg.
image-47.jpg.
Sprayed my coil to as it was looking sorry for its self
image-48.jpg.
But the main update is that i got my bike carb manifold
Been smoothing and preping my bay ready for paint but lazyness and no inspiration is the reason I'm taking so long.
Edited by p0Low
The guy you bought it off seems a right bellend!
and I'm liking the progress so far bud! Doing it properly pays off :)
Been so tempted by the mk3's lately :ninja:
Looking forward to seeing more updates ;d
Do ittt!!! I had a 6n then a 6n2 missed the 6n got a valver then had to get a mk3!! I really hope i manage to get it on the road! Ha
Been working on this all i can say is f#*k my life!! Finding the will power to carry on as its so boring!!
after image-50.jpg. Still need more cleaning,etch,primer,spray,laquer, LONG!!
Edited by p0Low
I now have the flywheel and clutch on. Gearbox has a leak but have orderd a gasket so hopefully will sort it! Also got a gearbox rubber mount will need to get that on to!
