MK3 Polo leak?
Hi...
I've got a mk3 polo gt and theres water sitting the the rear passanger footwell but i can't seem to find out were its getting in.....I've took the sunroof out and changed the inside seal inside the sunroof and cleaned the seal on the outside and it solved some of the water getting in but there still seems to be water sitting in the footwell/getting in??
Need help quick as don't want it to freeze inside the car...
J.
door membrane would first place i would check
Personally, I would take the carpets out and dry them thoroughly first. While they are out, dry up the water that's already there and then sprinkle some talcum powder over the floorpan(don't be shy with it). When the water comes back again, it will leave a trail in the talc so you will be able to trace where it's coming from :-)
Cheers...Will check tomorrow and hopefully sort it out...
J.
Fixed the leak in the door but there still seems to be a leak somewhere...I've found two holes in the windscreen seal where it looks like waters getting in...does anyone know how to fix this or where 2 get a new seal...
J.
is the battery tray mint ?
I've had this problem before, it was the water drips off the boot when you open it and falls onto the rear bench. This caused condensation in mine, but can also cause puddles if left.
