6N2 Dewipering
Hi just wonderd if there is any guides for dewipering the rear off a 6N2 polo or if not can anybody give me some advice also pics would be greatly apprichiated. thanks in advance for any replies :)
  • Views 957
Only from what I can remember but...
Remove the rear wiper arm by lifting the rear cap over where the wiper arm joins to the car. There should be a nut underneath, remove that and the wiper arm is off.
Remove the trim from inside the boot. Unplug the electrics and washer pipe, tape up the electrics to keep clean and dry. Bung, fold and tape/cable tie the rear washer pipe to stop from leaking.
There is I think 3 screws/bolts hold in the wiper motor in, remove them and the wiper motor should come out.
Replace the hold you left with with a rubber blanking grommit.
I know its may sound like quite alot of effort but its simple and doesnt take long.
Pete.
Not sure if there's any guides but its fairly easy to do
Remove the wiper arm and nut underneath
Open the boot and undo the two hex screws in the hand holds. Gently pull at the rear trim until all the clips are free and it comes off, its not unusual to break here so don't worry if it does
Unclip the wire from the motor and tape it up out the way, then remove the water feed pipe and seal it up
Undo the 3 bolts and remove the motor, you can get a rubber bung to fit the outside from halfords for about 3 quid, put some sealant around it to make sure its watertight :-)
thanks for the replies lads.. also why were on :p you`s no if MK4 Golf GTTDI front seats would be a straight swap into my 6N2 by any chance? just i can get my hands on some for pennies lol
No not without subframe modification.
Mk3 Golf seat do tho.
Pete.
Damn, ok cheers pete
