Mk3 heated washer loom and piping
I've bought two sets and out of four only one of them works! The car's going so here it is. Some kind of loom (never tried to fit it), at least the washer ends look good, the other end has been cut up somewhere along the lines. Various bits of fluid pipe and one working heated washer jet. You can have two non-working ones if you want too because I'm generous like that :lol:
Located in Cambridge, could post for £5 if you really want.
  • Views 309
may well take this off you. Are the connectors that plug in to the washers OK?
Yeah the washer ends look fine, although I've never tested them. I should say that the loom is probably not from a Polo (given how rare these were and how commonly they're on Golfs etc.).
Any idea if the broken ones are fixable or of they are the same as Mk2 jets? I'm really after a set.
I've tried to fix them but no luck. They're easy enough to take apart and there's a ~5mm disc of some ceramic-looking material which is the heater element which is what burns out or something. I searched pretty high and low for replacements but couldn't find anything - all I could find were too big :-(
This is everything:
Still got this? if so i'll have it. Completely forgot i had replied to this :lol:
