mk2 door cards in a mk3 + mk2 arch trims on a mk3
i am 99.999% sure they can be both done but i want pics to see the difference please
  • Replies 10
  • Views 4k
if you search in my build thread in the mk3 gallery "red G40 turbo) i have fitted mk2 door cards in my mk3.
the archs will fit as the dimensionally identical but without the rubbing strips for the doors
yeah i do know your build thread, epic! i didn't think you'd be running mk2 doorcards with a tt interior though, i'm guessing you've done what i want to do and fit the vinyl leather look ones to make a leather interior ;) and yeah i justed wanted pics of the arches on a mk3 really as i didn't find any through a search, i know they can be done but i want a quick look at what they will look like
not quite!
look a bit closer at mine;-) it just shows they fit in the hole.
in the hole
ignor the dash lol - they do fit with a standard dash in, you get about 20mm more room between card and dash as the mk3 ones fill it out.
so you needed more room for your dash then? i dont quite understand what your saying :lol:
is it possible to fit these ->
sill covers on a mk2f? i dont remember having holes for clips under the sills on mine
The previous owner of my G40 fitted the Mk.2 arch and sill trim kit. The only problem areas are the front arches have to be cut where they meet the front bumper and the rear arches have a bit of a gap around the rear bumper. Other than that, no one has ever noticed they're Mk.2 items :lol:
The holes for the sill trims are already there. VW just put round bits of tape over the holes and then undersealed over them :roll:
yeah i saw 6 patches on the sills and thought they must have been holes on the mk2, but i have had the car resprayed 6 months ago so i dont fancy drilling them out :oops: even though i would like to fit them
Kiz, what did you fill the recesses with on your door cards? Must say they look factory!
And what that big silver thing above the 'leecy window switch?
i used fibreglass to fill all the holes and all of the bits on the door card are from a mk1 Audi TT, the door handles, speaker grills and the side pouch for keeping things in. the big silver thing is just from a TT door handle to blend in with the theme. its where the mirror adjuster should be.
I thought thats what it was. So it has no function then.
Ah, fibre glass. Did you build a frame accross the pouch first, or just build it up?
It does all look factory and fits in perfectly with the dash. Which no doubt was the aim :?
