exhaust brace on m2kf
right basically i haven't heard what people do with the brace that stick out a couple of inches on the bottom of the car, because of mine i can barely park on kerbs (when i go to my mates house that is the only option for parking and i cant tell him i can't go over when i lower it more!) as it lightly grazes the kerb even when you position the car as best you can and the other week in the snow it was scooping snow up and tore the heat shield off at the back :lol: then the final straw was when i was driving down the entrance to work which is very pot holey and both front wheels must have gone into a hole at the same time and the brace slammed onto the ground! and i'm only 70mm down with 165/55/13's :retard:
how do the slammed go about dealing with this? do you just hack it off?
cheers in advance
Edited by JordonVW
  • Views 883
its bolted on, i just never bothered to put it back on and cars been fine since
doesnt it have two mounting brackets that stick out too?
nah dont think so. just 2 angled part on the underneath.. they dont stick out much
which brace are you talking about?
the factory bracket held on by 4 bolys at the start of exhaust/transmission tunnel?
OR
An aftermarket one bolted between the two wishbones. they hang very low.
I'm down 80mm and my factory one has some gravel rash but noting major. the box under the gear lever gets more of a beating than that.
if its the aftermarket brace, just get rid of it.
OR
factory one, i dont have any strut braces etc... obviously mines more likely to take a beating than yours then no matter the car height :lol:
