Dropped mk2 aerial into the wing
the title explains whats happened. is there an easy way of getting the aerial back out or is it gone forever?
and for future reference when the aerial gets pushed all the way in, how do you get it out again?
its simple stuff, but when you dont know.....
  • Views 1.2k
i've recently changed my aerial so this is easy to explain. if its dropped completely (ie not connected to top of wing anymore) then you need to find it!
jack car up and remove the plastic arch lining. reach up the wing and you should find the aerial.
if you just mean the aerial has sunk in and cant pull it out then remove the aerial from the wing and try and get it to extend by using it as a whip :p
to stop it from sinking again, use a bit of duck tape or electrical tape around the shaft to stop it from sinking.
hope this helps?
I've not got arch liners so changing my aerial was a P O P
Get your liner out, easy peasy.
As said, simply unbolt the arch liner, reach in and grab it.
A friend of mine decided he'd push the grommet I have filling that hole down into the wing one day, all I did was turn my wheels to full lock whilst parked up, unbolt part of the arch liner and pick it out from inside the wing. My car's lowered and has wider wheels too and I did it no problem, so if yours is standard height/skinny wheels then it'll be even easier to manage!
