Thinking about a respray...
Someone help, my polo is desperatly in need for a respray.. Not one of the panels is unscratched :-(
Now i was thinking about getting the whole car resprayed in the same kind of shade that it is at the moment, but in matte. However someone said if i just got 2000 grit and went over the whole car with it i'd get a similar affect for next to nothing...
Someone shed some light on this, do i attack it with sandpaper or not?
  • Views 1.2k
yeah fine paper like 2000 or a scotchpad would give a similar effect
and then maybe matte lacquer over the top to seal it all from the weather but keep it matte just an idea
This is one way of doing it, however if the scratches are deep ones, 2000 grit will not take the scratches out. If it needs painting, obviously the easiest way is to aerosol it, but if you still want a half decent looking car, get it painted then Matt lacquered. But if you wanna go Matt quick, try flatting down the laquer, you've got nothing to lose...
my god cant believe people are discussing this. yes flatting the car down with 2000 will give a matt finish but what are you going to do when it gets dirty? the dirt and grime will eat into the fine scratch marks and eventually itll look a mess. for a proper matt paint job it isnt cheap and you'll need to find some one very good to do it because if you get any bits or runs in the laquer then theres basicly sod all you can do (as with normal high gloss laquer you would flat and buff the areas with inperfections) if you tried to flat the matt laquer then it just dulls it more and you cant realy buff it as this adds gloss so abit of a never ending battle. I've painted roofs and bonnets matt before but never a full car. also for a good quality matt laquer its sometimes more expensive than regular laquers so realy have to weigh up your options as to what you realy want. there are people out there that will do cheap jobs but beware as they are cheap for a reason and when its the whole look of your car then its pretty much one of the most important points of the car so realy shop around and see other work that garages have done before so at least you can see if they are any good or just talk alot sales men, hope this has helped
one option you could try before going down the matt road is to wet flat the paint, then machine polish it back up, this would take out most scratches. (just remember you can only do this a few times before the lacquer will become too thin. (pro detailers use a machine which measures the paint thickness, so they know how much to take off))
A good rule, is that if you can get you finger nail in a scratch, then it will be too deep to remove.
Another trick you could use is to get a fine artists brush and the correct paint for your car, paint the scratch in. let it dry, then flat back level with the paint and polish up. it wont be perfect, but would be very hard to spot if you do it well.
I don't get why people assume going matt is a cheap way of repainting a car. IMO you would be better off, hiring a compressor, buy yourself a gravity fed spray gun and paint it yourself in a plain gloss celly or 1k acrylic based paint (i wouldnt recommend using 2k paints for diy spraying as its really dangerous stuff)
1k and celly are pretty good for diy use. not too difficult to use (i manage!), most are just thinned 50/50 with high gloss thinners. Celly can react with contaminents, so the panels being painted need to be super clean and well degreased. On a plus side though if you get runs, dirt in paint or orange peel in the paint, it is easilly wet flatted and polished back up to a deep shine.
I'm not a painter by trade, but i think it is possible to get reasonable results with a bit of practice. see pic below!
my mx5. door, front nose cone and rear quarter were pro painted, bonnet is original paint. front drivers side wing, window surround, hardtop and mirrors painted by me, in my garage using celly based paint sprayed with a cheap hvlp gun off ebay, run off a 25 litre compressor capable of about 8cfm
