LEAK! vague i know but i have an unwanted leak.
right, i gathered this is prob a pointless thread, but i have an annoying leak, so i just wanted some info from people in the know of where abouts it might be coming from.
Every time i park up my car in the rain, i come back to it to find a puddle (trust, its not shy to make its presence, its huge) in the drivers footwell, and behind the drivers seat. I've tried sitting in the car with someone spraying a hose at it but i couldn't see any leak. Plus my rear window is constantly misted/damp from the inside!
Any clues guys?
Mk3 polo..
Cheers in advance
  • Views 963
I've heard to check the sidewall by looking under the dash, apparently it's known to come through the joint where the door is bolted onto the car - think mine does this slightly too - if not, check that it's not coming in through your door! Mine currently poors in over the bottom seal :(
its often the seal behind yr door cards
guttering blocked with leaves etc under the scuttle causing the water to build up under the scuttle and leak through the grommets etc in the bulk head?
battery tray? or the membrane behind the door panel?
or a deteriorated gromit in the scuttle, but thats more likely to be passenger side.
