Mk2 Breadvan full of water :(
Took the Breadvan out for the first run in a month this morning.
Drivers side was full of water, both in front of, and behind the seat. Must have scooped half a gallon out.
The door seal looks OK to me. Are there any common places these leak?
  • Views 995
you sure its water?
could be the heater matrix leaking, whats your coolant level like?
i.e it could have frozen which has split a hose and then melted out,
It's definately rainwater chum. I tasted it just to make sure lol. Coolant level is fine, I flushed the system and filled it with antifreeze about 6 weeks ago.
check you battery tray. probably rotten. other way I've seen the front get flooded is due to rust scabs around the front windsceen. if left the scabs cause a pinhole and let in a suprising amount of water
It's coming in behind the door card. Shouldn't be too hard to sort now. Cheers fellas.
Probably your door membranes then. Easily fixed with a rubble sack and some gaffa tape.
