polo infomation ?
does any one know of a thread on here that i can find the weight of a mk4 polo. or if any one knows
thanks chris
  • Replies 11
  • Views 1k
just googled it and apparently its 972kg... not sure how correct that is though.
o how did you fns that all i found was crap or all new things, but thanks it sounds about right just under a tonne :)
That does seem right, there about 200kgs heavier than MK3's and the MK3's weigh 750 - 775kgs
all vw seam to get heavyer :(
Mk2s weigh between 730kg and 810kg (all models above 785kg are diesel).
Check under the bonnet for an information plate, that should tell you how much it weighs (if mk4s have one).
The 6R is about 150kg lighter than the 9n3.
about the same as 30 average sized elephants. i think the 972 is dry weight, about 1100 at the kerb i think
my car is 987kg Kerb...........
oo really, what u got in it interior wise? like to weigh mine, 15's, leathers, sub etc
15's, alloy engine (where most of the weight is saved), air con and pretty much standard. I was wrong 987 is the dry weight 1031Kg is the kerb. IIRC the 6n2 16v (100hp, not 75hp) is 7kg lighter than the 6n 16v.
