Heaters Not Working ?
Just got a little valver that needs a bit of TLC and one of the problems are that the heats do not work any ideas what it could be ?
  • Views 730
Could it be as simple as a Fuse or Relay ?
Do you mean the blower doesn't work, or that you don't get warm air through the vents?
The blowers dont work at all dude
Edited by Po*Low*
You have a valver now?
Check the resistor and fan..could be that water has got into it!
Pull down the foam above the passengers footwell and have a gander - test your resistor from your polo into this one and see if it works!
