Wetness
I have taken out the seats in my polo today for my roll cage and noticed as I lent on the drivers side rear on the seat floor it to be ringing wet the door seal looks ok has any one got any ideas
  • Views 853
we had similar trouble with a customers leon cupra, it rook us 6hrs to find the cause and it was such a silly thing, when someone had fitted a sub wire kit they had drilled the hole in the bulkhead in such a place that when it rained all the water that was coming down the drainage line from the screen was going streight into the car and slowly soaking through to the rear footwells, realy silly thing but we stripped te interior (seats and carpet) i sat inside while the lads poured water at one point at a time until we found a leak, hope this helps
Lift your battery out and look for a hole there, failing that, door seals, then take the doorcards off and make sure there's a membrane behind them and it'ws stuck in place properly.
There is no plastic sheet in door but I know the battery tray is not water tight but front floor is not wet will try the door plastic see if that helps
The floor at the back's lower than the floor at the front, so it could still be battery tray.
agree, when we did the leon it was the back foorwells that were swimming but it was coming in thru the bulkhead, you'd be amazed about how it will travel thru your car
I had a similar problem with wetness on the floor, found out the rear windscreen washer pipe had come loose on one of it's joints somewhere near the floor
