paintless dent removal kits PDR
Hi
so after getting stupid quotes for 4 small dings and one medium size dent in skirt I'm thinking of doing it my self.
I've seen this kits on ebay and do think they will work as the dings are so minor with no paint creasing etc
has anybody ever seen these used in real life or used em them selves?
I've seen the whole kit and I've seen just the suction handle.
http://www.ebay.co.uk/itm/LARGE-SUCTION-CU...=item3f0802d329
http://www.ebay.co.uk/itm/Auto-Car-Bodywor...=item4cfa6b83cb
do let me know on the feedback
  • Views 875
certainly worth a try for those prices, we have a suction cup one at work (first link) and I've used it on loads of peoples cars for pulling out football dents, works realy well most are no longer noticable.
all i will say is good LUCK, i have had one of these kits myself and the guy we use at work for paintless dent removeal has been trying to show me how to use it for the past year and I'm nowhere close to being able to do it right, the instructional dvd is usless you realy need someone to show you face to face, i always end up stretching the pannels too much and tit the pannels, it seems easy enough but its a hell of a lot harder to do than you think, and i do pannel beating and spraying for a living so i understand how and why the pannels/metal moves. 4dints shouldnt cost too much, couldnt do the one in your skirt as you cant get behind it, would need a single side welder for that but without seeing the dints you could be anywhere from £40-£80 if you were to fetch it to us then the skirt repair on top, hope this helps, dont want you going wasteing your money
sorry i didnt look at the links before posting, i asumed you were using the dent removeal bars, i have a suction cup but no way does it get rid of all the dent and if there only minor then this will be no good, as for the glue gun kit, i also have one, but a bit more of an advanced kit and this is also a specialist thing, unless you have loads and loads of practice and are very talented then you wont sucseed, sorry to put a downer on things but sadly this is the reality of dent removeal, theres a reson the pros charge what they do, its a true skill, also be carefull of using cowboy dent removers as I've seen some shoddy work and we went through 4 guys before we found the one we now use who is fantastic
cheers guys, and euro ill keep that in mind, ill order the suction cup first as its the cheapest and see how it goes, i dont mind getting the side skirt done from a pro as it is a lil deep but the rest are all minor dings I'm sure of it,
