custom home made induction kit
Hi
i want to install a induction kit, not so much for perfomance but more for show and the noise, i dont want to be spending stupid amounts of money on one either.
so I've been looking at some stuff and though i could make one my self?
items i will need is :
90 deg silicone joint, then another 90 deg joint so the metal cold air feed will join with it running down to the front grill. a mushroom filter with relevant clips and a oil breather pipe and a heatshield.
heres a photo of my imagination :
top two red circles are 90 deg joints
red line is metal pipework
mushroom filter with heatshield at the bottom
tell me would that work and also would it be safe or with this cause ecu problems?
i know it sounds nuts but i thought ill ask lol
cheers
edit: obv i will remove original airbox etc, this is just a stock photo off google.
Edited by mista_khan
  • Replies 18
  • Views 3.1k
i dont see a problem with it. better than just sticking a filter straight on the top! at least youd get cold air
wow I'm gobsmacked, i was thinking you would say I'm nutz lol, great, anything important i would need to do to make it work or is it as straight forward as that?
cheers
i wouldnt say your nuts, youd just be making the same as what a fair few other people have but for much cheaper!
shouldnt have to do anything else i dont think, apart from getting a filter for the oil breather, but there like £5
i'd say have it coming off to the left instead of the right as there is more space.
need a pic of it without the airbox really, id say the right would be best IF you can get it to fit, mainly as it will be more in the centre of the grill so there may be slightly more cool airflow, rather than have it stuck behind your headlight. i dunno though, I'm far from an expert ha!
just saying thats where the original is and there is more space because they layout is the same as the 1.4, the is also less heat soak because you are away from the exhaust and coolant hoses.
ah i see, maybe on the left with a cold air feed to the grill for the best results?
looks wise that would be a turd.
for reference to the OP the original inlet goes into the front wing to get the cool turbulent air from round the wheelarches. short of not having a bonnet it's the best compromise of air and cold air.
I know yours is FO'SHO so ultimate results don't matter but the standard placement is very good.
buy my typhoon induction kit. can run it either on the long pipe or the short pipe will look like the diagram you have done.
its in the for sale section
thansk for the feedback people, but I'm thinking if i have to put it on the left side it will be more advance in terms of more items needed etc and I'm just a noob at these things. thats why i placed it ont he right as all i need is 2 90 deg joints, 1 pipe filter.
also wouldnt me having a heatshield help out if it was on the right?
cheers
hi
what about this way, i could manage to do this, difference one be that last joint wouldnt be there and instead there will be a mushroom filter at the end?
woudl that be a better placement?
cheers
thats the way i was referring to :thumbsup:
bloody hell them clips are definately enough on that haha!
this is what i did, bmc cda (bit differnt now as its metal tubed no pic's though)DSC02275.jpg
o yea, i think i can sort something out, wierdly enough i found a guy in usa whos shipping typhoon kits in red for £180 delivered brand new, i just love the noise on the typhoons but the price tag is way too much, I'm going to do some measurements today but I'm not sure about the inlet diameter size for the air filter ?
yes joedee that looks neat in terms of cutting that hole for more cold air flow but I'm not a fan of bmc looks lol
