delete
delete
Edited by performancevw
  • Views 907
Might be wrong but I think someone at work once used spray on underseal over the bit he had repaired, really light layers, really light!. Looked pretty convincing (although it was a while ago don't really remember) not sure how long this would hold up mind. And also not sure if you could do it for the whole length of the bumper but give it a try. Or just smooth all the texture and spray it black?
you can get textured paint :)
yes you can get bumper texture coat but just note that it ins plastic so you wont be able to clean it the same (viynl gels ect), just a simple wash should do, when applying it make sure you do it in very light coats as if you put it on too heavy then it wont dry correctly and youll ruin it. try a local motor factors to buy some from or i do believe halfords also sell it
That was jack1's old saloon - he built my old offset bumper for mine and used textured paint for it :)
