sanded down?
thinking about sanding the car down, very slightly so i keep all the paint but will see some parts of primer through it and matt the whole thing.
anyone seen this done before? pics?
also what grade paper would be best, don't want to go through to metal and don't want to see big thick sanded marks in it
cheers. ps: not looking opinions on it as i know allot of people will hate the idea lol.
  • Replies 15
  • Views 1.4k
If you're just going for the "give a shit gonna scrap it anyway" look as I call matt black. You should be able to just score the paint up with a scotch pad. You don't need to go to primer, just make a rough surface for the paint to adhere to.
nonono it's not getting painted, just sanded lol. matt blacks been done waayyy too many times.
think i understand what you mean, try wet n dry, 1200-1500-2000 grade, they will give a dulled and sanded effect but wont show up loads of deep scrach marks, alternavively if your wanting to break through in places then you can always use a lower grade first to get down to the depth you want then go over with finner papers to get rid of the deep marks
You'll go through to the metal on any raised bits, particularly the lines/creases but also on fractionally damaged areas you can't even see. Just dont sand the creases.
Keep an eye out for contour lines coming up as you sand. You'll be in the most control, and have the best effect, with a less aggressive grade - i recon 500-800 for a sanded look or 1200-1500 if you want it more a satin sheen. The primer will come through very fast and it doesn't protect against rust, so spray some matt laquer over any any primered areas.
If your intention is a tidy satin version of the current colour, you'll be lucky and need to spend great care and time. Better off getting a respray in a satin/matt colour of your choice (all metallics are already matt, which is why you have to spray gloss laquer over them afterwards).
not worrying about the lines showing through, think it might actually look pretty sweet tbh. also not wanting it to look like satin/matt paint, last car had that. will the primer rust quickly? was intending to have bits of isapon and filler showing too, love the random patterns it all creates when sanded.
will isapon go bad with rain on it or anything? roughly how long would it last
bits i'm worrying about is the tight areas, will just have to take care with a scotchbrite pad and hope for the best i guess.
i'l give it a go with 1200 and see what it looks like :) cheers
So basically you want your car to look like its prepped for paint?
ahhh, yeah basically. only without the sanding marks
You wouldnt have sanding marks if it was prepped for paint.
An alternative would be to fill all the dents with filler, as if you were prepping for paint, and then rub them down etc. Then scotchbrite the rest of the car. You could actually spray primer over the top coat and then blend that in using wet and dry. That way you dont risk running through to metal and the metal willl be protected from rust too.
any areas which contain filler (you may not even know it has any) need to be covered in paint. filler is porous and will expand and go manky and will need removing and refilling before painting.
i laugh at children i see with bodyfiller over there car as it soon ends up on the local weighbridge
I dont think longevity is a concern tbh Kiz
not worrying too much about it lasting long, want to do something different and like the look of cars when sanded so why not :)
spraying a few layers of primer over any dent or scratch after being repaired is a good idea, even when taking it easy with filler it usually goes through to metal anyway. the arch's will need to be rolled out ridiculous amounts so will need primer'd too.
does primer protect against rust and how would the paint protect against it after being sanded down? suppose it's just got allot to do with how much paint is left i guess?
Surface rust will come through the primer eventually, like they've said primer is porous (absorbs water)
The 'sanded paint' will protect against the elements.
Max
Matt laquer (or just sanded gloss), as a skin over any primer and filler should protect it from moisture sufficiently.
the look you're thinking of is called "patina"
if it's real patina, it's caused by the paint burning/fading in the sun in hotter climates
http://images.google.co.uk/imgres?q=patina...=1t:429,r:9,s:0
that camper looks lovely... that look suits it perfect!
