Has anybody ever fixed the leaky footwell of doom on a mk4?
My opassenger footwell is sodden wet, seems to be coming over the door seals when i hosed it, so I'm baffled.
I've tried changing the door seal but saw no change.
I've had a new windscreen about 8 months ago but it's been happening for ages so i dont know whether that could be the cause.
has anybody ever successfully sorted it?
if so, what was it?
  • Replies 9
  • Views 1.2k
both passenger and drivers leak on mine and the openair roof!
i hate it, its catch 22 with me, I hate habing a mucky car but i cant clean it as it will blow my hoover up haha,
The foam sheets / "door membranes" behind the door cards tend to be ripped or punctured. This means water can get through them and leak over the door seals!
Whip your doorcards off and take a look..if they're buggered just get some replacement insulation type foam and make your own new one
could well be your pollen filter, does it do this when its raining?
Yeah it gets soaked when its raining!
Then i would try that first as that was my problem and i had all the symptoms as you have
pollen filter 95% sure it will be
Just fitted a new one today, still leaking in ://
got the same problem on mine, tried all the pollen filter no luck. turned out to be the bottom seal on the windscreen has lifted up slightly, soaks the car every time it rains! worth checking
