6N2 GTI fronts grille removal
Hi, simple question - how do I remove the front grille from a 6N2 GTI? Click tabs don't seem to want to come out. Have a new GTI grille badge to put on and can't get the old one off, so need to remove the grille.
Thanks,
Rich
  • Views 861
Popular Days
There should be 4 tabs in total along the top of the grille and they habit of springing back in and holding the grille in place. Make sure all 4 are released then I tip the top slightly forwards to stop the clips re-latching and pull the grille up.
It might help releasing 1 tab at a time and tilting the grille forwards slightly each time if they keep re-latching
I usually used a small flat head screwdriver to push the tabs forwards to release
HTH
Edited by Duey
