Will 205/50/16's fit an 8'j wheel
This table says not but I'm guessing with a little stretch they will,
tyre width.
Rim width Min tyre width Ideal tyre width Max tyre width
5 .0 inches 155 mm 165 ou 175 mm 185 mm
5.5 inches 165 mm 175 ou 185 mm 195 mm
6.0 inches 175 mm 185 ou 195 mm 205 mm
6.5 inches 185 mm 195 ou 205 mm 215 mm
7.0 inches 195 mm 205 ou 215 mm 225 mm
7.5 inches 205 mm 215 ou 225 mm 235 mm
8.0 inches 215 mm 225 ou 235 mm 245 mm
8.5 inches 225 mm 235 ou 245 mm 255 mm
9,0 inches 235 mm 245 ou 255 mm 265 mm
9.5 inches 245 mm 255 ou 265 mm 275 mm
10.0 inches 255 mm 265 or 275 mm 285 mm
10.5 inches 265 mm 275 or 285 mm 295 mm
11.0 inches 275 mm 285 or 295 mm 305 mm
11.5 inches 285 mm 295 or 305 mm 315 mm
12.0 inches 295 mm 305 or 315 mm 325 mm
12.5 inches 305 mm 315 or 325 mm 335 mm
  • Views 1.5k
205 millimetres = 8.07086614 inches
Edited by polovr6man
Yes they will fit. You'll struggle for fitment though, like 195 40 16 is standard radius, you'll be bigger and wider, struggle for anything lower than like 60mm id imagine
i doubt youll have much stretch if any at all. I'm running 175/50's on 8j's and even thats not stretched a silly amount
He doesn't want stretch. He wants wide tyres for traction but 15s or 16's due to brake size
Pretty big tyres. 205 40 better
Okay great, i think the tyres would probarbly look silly anyway but they are cheap, they're semi slicks maxsports
yes i know but he mentioned it in the first post, just sayin!
