MK3 Removing Window Wiper
Hello!
I am in need off a new window wiper arm and i have been to my local scrappy and there is one, There is a cover thats over the bolt and i can't get to it,
How do i remove front window wipers?
ASH
Thanks in advance. :-D
  • Views 787
Get a small flat head screwy under the cover, pop it off and it will expose a 13mm nut undo that, and then the wiper arm will pull off, might be a bit stubborn mind.
Ok man, Thanks alot..I'll see how it goes!
