Into the garage she goes... :(
So i bought my 1.2 MK6 polo in August which had a squeaky brake issue, this was then sorted my new front brake discs and pads, and everything was running smoothly and i thought she was perfect! She was fully serviced and MOTd when i bought her and has since had 3,000 miles on her. Within the last week or two I've noticed how getting her in and out of first gear has been getting a bit stiff/sticky, i dont know whether this is related. Then about 5 days ago, battery dead after a long drive and only being off for a short while, not even a whole night. Bump started then off we go, perfect. Then NYE, cleaned her inside so she was looking fine, moved her to outside the gate, turned her off because i forgot my jacket, ran in, came out within about a minute, and no start. Nothing, tried bumping her, and she sounded absolutely hopeless and like she wasnt running on all cylinders. could anything worse happen on NYE? well I've replaced the battery to no avail, and shes going in the garage thursday, hope its not too costly, but having no car sucks balls.
  • Views 1k
You are right about that!
currently in between cars myself.
Doesn't sound like anything overly complicated, i'm sure the garage can hook it up to one of those computers.
Hopefully its not too bad, was hoping to upgrade it a bit this year, not spend even more getting it just running :(
i had this same problem with my car, i went for a 3 hour drive, came home turned him off to run in, came back out and was completely dead. Couldnt bump start at all... i had a new battery and alternator fitted aswell as a new starter motor, ( was on its way out anyway ) ....after a full charge and a bump start it worked fine form then on...still very cautious about it dying again tho.
I've had similar thing happen on NYE and NYD. NYE Driving my MK2 GT down the road turn a corner and it just died would turn over but won't start AA was two hour wait and it turned out to be the ECU had died.
Long time ago had a MK2 Astra GTE. NYE went to start and nothing spent loading trying to figure it out turned out to be one burnt out wire under the gearbox.
My friends MK6 1.2 died recently been diagnosed as the timing chain has slipped
Hope you get it sorted soon.
Sounds like what I've had with both my cars, they both cost me loads in repairs in the first year of owning them, my current car cost me 2k throughout october and november but at least now I know it should be good for a while (touch wood).
Tried bump starting her and also bought a new battery as the last one tested at 11%
Waiting to hear from the mechanic, shed turn over fine but just wasn't firing up :(
New spark plug needed.
And also the timing was out or somthing do that needs replacing/repairing, what does this mean exactly?
