6n2 gti parts into lower specc'd 6n2s
Swear there was another thread on this recently, but i cant find it.
I know the majority of exterior parts are all changeable.
However on the inside, is the GTI wiring loom the same as the lower Specc'd 1.0/1.4 loom? As in, if i got hold of all the climate control components from a GTI, would it be plug and play? Like the fog lights are?
Cheers guys
  • Views 788
Pretty sure the loom for a gti is slightly different because it has the VVT sensor on the cylinder head.
If you got hold of the climate control components from a GTI and the wiring to go with it then you could do this.
You will need the air con pump and the bracket that it mounts too, the alternator and power steering pump also mount to this and the plumbing of the hydralics is different as in the pipes are a differnt shape.
Find out everything you need and go see a guy breaking a 6N2 GTI you'll find everything you need and things will become pretty self explainatory.
all the heater flaps are different as well, as the flaps are all electronic with climatronic whereas they are all manual without, I read about someone adding it on to a mk4 golf and it was a hell of a lot of work
To add aircon climacontrol into a non GTi is an absolute bitch, the looms are different for a start plus there's the expense of the parts but the main thing would be would it be a good idea to put a heavy drain system onto the 1.0/1.4? They already don't have much power as it is :lol:
if anyones interested in doing it,I'm currently breaking a 6n2 with complete climatronic aircon. Starting to strip it now though so won't be about long!
