understeer in mk2's and mk2f's
I've got a mk2f breadvan which is loowered 80mm around and I've only got standard wheels on it but i get quite alot of understeer, and recently i have purposly tried to get the back end to step out but it just grips, its only a 1.0 aswel so its not like thers alot of power.
does anyone else get this? in coupes, loons or breadvans?
or is it that mk2/f's have bad handling front ends?
cam
  • Replies 52
  • Views 3.4k
yahh.. pretty standard old polo handling lol
Sounds about right to me. There are some uprated suspension parts on here that may help, but I don't reckon it's worth the hassle.
Really? arb blocks are "essential" on a lowered early polo, up rated TCA bushes also make things feel tighter. And it goes without saying that a subframe will improve things.
But yeahh they do have a reputation for having a "detached front end"
Never driven one with a subframe and tie-rod conversion. But i can imagine it sorts the problem out very well. Essentially creating a wishbone.
Without doing away with the arb set up though, it's never going to be ideal!
It is possible to turn understeer into lift-off oversteer, but it's nowhere near as enjoyable as in a mk1 golf!
i still need to get myself some arb blocks, just worried that there more money than there worth! 60 odd quid for some blocks of nylon... lol
Yup :) I've yet to find a corner i cant go round flat out, i'll keep trying and let you know which lets go first the front or the back...
Get some arb blocks on there and you should notice the difference. Problem with lowering an early polo so much on standard front strut set up is it gives you camber you can't correct which isn't going to help handling much either.
Even with the blocks tho my front end seems like It's twisting all over the shop at times I'd like a sub frame but don't fancy lifting the front end up to run one so might invest in some popus bushes for the tca's and see if that improves it any
x2
But from my experience, with a decent set of tires, subframe, coileovers and decent road surface, it'll suprise you how much it will grip. Then it will be the arse end to let go first, yours, then the cars because you backed off the throttle and left yourself with 70mph lift of oversteer to deal with in the middle of the roundabout :lol:
Edited by .Joe
man, the camber is a pain. camber wear sucks ass! there must be a way of correcting it!
Can you not get camber adjusting top mounts for polo's?
It's not some thing I have to worry about tho seens as my mk2 already has front camber adjustment :unibrow::lol:
ORLLI? u got a golf setup I'm guessing?
Yeah mk1 golf coilies
jelous...
i should be getting front coilies at the weekend :ninja: polo ones though so no adjustment :(
They are designed to do that.. and its a front wheel drive car.
what make and model of tires are you using, what tire pressures are you running.
i use phil j 80mm lower springs/shocks polybushed at front with 14x6 wheels and mine grips fine with no camber wear but in the wet its abit risky on some corners
jelous...
How much are you spending on the coilies? I got a mate that sells mk1 coilies converted to fit the early polos and with full fitting kits, literally bolt on jobbies
and how much are they guy please
around £200, there pps ones. the only problem i can see is that they dont look like they go low enough.. he has them all the way down! maybe chop a coil off? what you reckon?
http://www.clubpolo.co.uk/forum/index.php?showtopic=269861
It will NEVER go low enough using a MK3 strut. FACT :lol:
:crybaby: :crybaby: :crybaby: :crybaby: hmphh
However, being that low means you really cant use any of the power you have...
Need to find a happy medium, which always means archgap :lol:
Iirc they use the damper from a -80 lowering kit so not a lot of lowering in them after that before bottoming out, remember the dampers in them kits are actually designed for the -40 kits. If you want to go low I'd save your money up cause you might as well just get a -80 kit and chop a coil off that
Not sure Matt but I'm going to see him tomorrow so i'll find out more
Bullshit
I'm already down 70 with eilbach dampers, just want coiliessss hmm. how much are the golf setups from your matey then?
