understeer in mk2's and mk2f's
Its not bullshit haha
Not on our roads anyways.
  • Replies 52
  • Views 3.4k
However, being that low means you really cant use any of the power you have...
Need to find a happy medium, which always means archgap :lol:
its only an afh tobes, I'm not driving a supercar :lol:
I cant use my AAV to its full potential without breaking my spine :lol:
I'll have it even lower soon.. dunno why I'm bothering with the AFH lmao.
I cant remember exactly, but he said to me its be about 400 with fronts n rears, possibly less if you exchange you are standard MK3 strut (for the steering arm)
That was with B/N MK1 golf hubs.
Don't quote me though, i could be wrong.
hahaha, mine seems to be lacking some grunt compared to the first week i had it on the road, i have retarded the timing mind, i had it fully advanced and got 10 miles on a tenner of fuel :lol: now getting 50 or so.. still need the timing doing and the carbs setting up really, but i may just sell it in feb
Edited by erixtar1992
Never driven one with a subframe and tie-rod conversion. But i can imagine it sorts the problem out very well. Essentially creating a wishbone.
Yup :) I've yet to find a corner i cant go round flat out, i'll keep trying and let you know which lets go first the front or the back...
x2
But from my experience, with a decent set of tires, subframe, coileovers and decent road surface, it'll suprise you how much it will grip. Then it will be the arse end to let go first, yours, then the cars because you backed off the throttle and left yourself with 70mph lift of oversteer to deal with in the middle of the roundabout :lol:
X3
Almost lost it entering the M4 at 70 one wet night after lifting off due to a lake, slight brown trousers moment but the car corrected itself. otherwise it sticks like glue to the road with a nice bit of front tyre slip if provoked.
That does sound familiar Toby, all the Cv joints are new and new bearings in hubs ect
And it is bullshit, how many of my afh polo have had arch gap? And I use plenty of the power they have. It's been so long since I drove a polo on a philj kit but I'm sure my coilies ain't as harsh as my first polo was on the shocks and springs, yes its stiff but not to the point of putting your spine into your brain :lol:
Edited by Mclovin
RR day, I'll take you out in mine and hammer it around some gay roads
You will be glad to get back into your own polo :lol:
Bumpstops are not the one. Also, i have too much arch gap for my liking. I fucking hate my breadvan cus its such a shit ride.
like seriously, i felt like getting out and just booting it till i fucked my foot up it was pissing me off that much. And all i was doing was driving 5 mins away to the shops :lol: I've never felt so much rage towards a car in my life.
Anyway, enough ranting.
He's hoping to bring a display model :unibrow: to the RR.. Which will hopefully be my kit :ninja:
New everything pretty much, correct top mount too to fit the larger MK1 golf shock. (to save doing what you had to do Guy)
isn't that part of the fun of owning a polo?
If you lower a car and don't correct the mess you've made of the suspension geometry, of course it won't handle properly.
Thinking back to '03 when the suspension and tyres on mine were standard and maintained properly, i remember it being easily tail happy, despite vague steering and a soggy squatting nature.
They are designed to do that.. and its a front wheel drive car.
what make and model of tires are you using, what tire pressures are you running.
ohhh there sum shit tyres so that wont help either! at normal pressures probs around 28.
i have been thinking about the geometry I'm going to pull some notes out and make a few drawings and calculations see what i can find out and see if there is anyhting i can do about it........................when i get some time
Get some decent tyres and it should sort out your under steer for you.. I would check the pressures and well as I think 28 is too high. On my coupe on standard wheels I ran 23. It won't help tyre wear or fuel economy but it weighted the steering up a bit and gave a better grip. But decent tyres are a must! It won't completely remove it but enough for the 1l engine!
Get some front castor correction blocks for a start, so you get your castor back. PhilJ might still sell them? Original Gladerseite ones are popular too.
At what height do you think it is necessary for arb blaocks to correct caster? My mk2f has the 70mm jamex kit i think and i have noticed the front of the wheels poke out more but i thought that might be due to the shape of the front wings
Castor dosnt effect how far the wheels poke out. Its the angle that the strut is pointing (basicly)
I'm lucky because I have access to a Hunter Pro Align system that measures everything. So when I've got my car running correctly, I'm going to fully set it up (depending on whats available to help correct things, as I hear the adjustable top mounts are wack.)
To OP:
I like the fact my polo understeers, lets you know whats going. Been loads of posts about this before its a common thing with them and as someone said, Its all part of the fun I thought lol :)
I'm thinking of toe arent i, so it sounds like mk1 goof coilys are the way forward then what is the cheapest you could do it but not diy'ing the fronts?
After all of the advice given, surely this is the most critical? No matter what you do with the suspension set up in terms of lowering, TCA and ARB upgrades etc etc, if your only point of contact with the black stuff is poor, then your never going to achieve much.
I've got poly bushed TCAs with standard ARB bushes. I've also got a lower strut brace that joins the chassis in front of the ARB. This set up is pretty good for me, I run my tyres at 30PSI. In the dry it won't understeer at all and I've got shit tyres. To be fair it is vastly improved now I've replaced my old knackered philj dampers and springs with a brand new set.
Pretty dodgy in the wet though, I put that down to shite tyres.
I've cracked on tonight with the coilovers- I've been somewhat busy with other things. will have hopefully 2 sets (1 new and 1 2nd hand) on show at the club polo RR day.
prices depend on what you are after- more expensive coilies cost more to build and if you require all the parts for a bolt on.
pricing is in the £410 mark for a set of brand new front and rear complete with all components (top mounts, bearings, hubs, CV joints and boots.
2nd hand depend on what i get the parts for. all come looking new regardless.
front air ride is also an option but at a cost of roughly £120 more and you have to buy the bags - as exchange rates vary from the US
what coilovers?? custom ones or mk1 golf jobbies? would be interested in the second hand ones depending on price :)
My last mk2 never understeered. It was bog standard height, wallowly shocks and springs. What makes them let go is poor choice of tyre. Hard suspension will make them break away less progressively.
mk1 golf.
the cheapest coillies are £160 to buy (I'm not making these in massive bulk to get discount) i had a 2nd hand set come in cheap but there already claimed, if you supply your own i can modify them if if people want but only if the rest of the kit is bought. i dont make much from these so I'm not just doing peoples struts for them to take hours of my time for a tenner
mk1 golf.
thas fair enough, i only need fronts though. what would it cost me to give you some profit?
il pm you over the weekend with a pricelist.
i do have a pair of just fronts and i cant remember if higgo claimed them or not- il check.
cheers mate :)
