swirl marks
anyone know what to use/how to get rid of them nasty swirl marks? I've tried everything!
  • Views 965
cable polisher and mop it - will have to mask up other surfaces etc.
cheers pal ill give that a go
machine polisher with a soft mop head and a good quality super fine compound, if your machine has a speed set ajust then set to a highish speed, all machines are different so hard to say an exact number but dont have it on full, around 3 quarters should do. do the pannels in small sections and wipe with a microfiber as you go.(you may have to go over some areas several times to get them completely out). you must have patience as its a timely job. may i recomend 3m yellow top compound (can be found on ebay or from a motor factors) and use the 3m yellow soft mop to match with it. there are others around but after trying out a fair few weve found this to be best, also if you catch any rubbers(which should be taped up) then it soesnt leave a white residue, hope this has helped you
If they're just 'holographic' (i.e. you can't feel them) then Bilt-Hamber AutoBalm got rid of mine.
Yep either a rotary or DA polisher will do the trick. DA is safer for the inexperienced polisher.
It depends on how fresh the paint is, and how think the lacquer is as to compounds and mops.
Would suggest getting yourself over to detailing world and have a read there
alright then, thank you guys alot for the help, I'm gonna have a go over the weekend
