Rubber bump strips Clipped or stuck (on mk2 breddy)
Does anyone know if the rubber bumpstrips on my mk2 breadvan are clip on or stuck on, if a take them off will there be holes behind them?
Edited by DanIOW
  • Views 724
They're stuck on on a 6N mate, not sure if it's the same on a Breddy :/
Cheers mate spose i can take the door card off and have a look from the other side and see if theres holes
Stuck on with two-tier rows of double sided tape - i found the best method for removal of the wide rubber type was to stand on the end of it, then pull it back from there by hand.
