'ello - I'm New 'ere :)
Hello everyone :)
Thought i'd put up an intro thread - would have done one a few days earlier, but combination of a broken keyboard, and too much still happening in the christmas/new years aftermath just got in the way :D
So - i picked up a 6N1 Polo from a friend of mine, out of a hedge, to be precise. It had been sat there, collecting green moss for about 6 months, after its previous owner decided to abandon it. Turns out, it had been abandoned by a friends brothers girlfriend (convoluted, i know) several months prior. He had all the paperwork and had been told to get rid of it. Now, he was going to go and weigh it in for scrap metal value (about £150), but i said 'i'll take it, if you don't want it.' The battery was flat, but started easily after a jump. There are a few small things it needs fixing, but they're so minor, in the grand scheme of things.
List so far:
10 Amp Fuse (fixed)
Needs the battery to be properly charged (sorted, given the Epsom Salt treatment)
Drivers window doesn't work (New Motor?)
Passenger window works, but needs new runners (stupid clips disintegrated)
Tail-light bulb (fixed)
Passenger side Wiper Blade (got a whole new set for less than a tenner)
Exhaust Front Silencer (Cheap to fix?)
Drivers side sidelight doesn't work, but main beam does, oddly... (fuse is fine though, relay issue??)
Rusty sills, but i figure it needs wire brushing and repainting.
That's honestly all i can find wrong with this as well. Paint is faded on the bonnet, and on the roof, but that's cosmetic, and nothing a little polishing wouldn't solve. It's not as simple, or as retro as i'd like, but hell, beggars can't be choosers, and i paid ZERO for it. It has power steering, electric windows, electric mirrors, a sunroof and a Stereo.
Poor thing definitely needs some TLC!
Plans for it are - i'm going to use it as a daily driver for a few months, until my fiancee passes her test, and i go back to driving my Toyota Supra. It's not going to be slammed, it's not going to have alloys, big exhaust or any modding other than mayyyyybe a camshaft (Polo GT one fits, right?) to squeeze a little more out of the lump. I'm thinking 60 to 75hp isn't outside the realm of possibility for the lump. What's the engine code on the 1.4, by the way?
Anyway - here, have some pictures:
Yes, those 'orrible plastic hubcaps have hit the bin already - nothing wrong with the stock steelies!
May need a little bit of a clean...
  • Replies 8
  • Views 1.2k
Welcome along mate, be good after a little loving! Sidelight bulb faulty? Sidelight and main beam are different so change the bulb if u haven't already.
I have a 1.4 8v and engine code is APQ
Yeah - new bulbs were put in, along with checking the fuses - i'm missing four though...which is odd - cause other than the sidelight, everything seems to work O.o
APQ? Good - thats what i thought! :D
Welcome.. :)
Now that needs a dam good clean! :)
Welcome to the forum :)
Thanks for the welcome, all :)
Turns out today that the exhaust problem is simply a case of the front silencer having a 10p sized hole in it - looks like an eBay generic replacement is about £25 - but is it something that i can fit myself, or would it be better to get a Garage to do it? I'm no stranger to working on cars, got pretty much every tool under the sun, but i know from prior experience that VW likes to do things a little differently!
Sidelight issue sorted - i hadn't taken into consideration that the sidelight was a separate bulb from the main H4 bulb, and the wedge bulbs are notoriously hard to get out here in France. Luckily, they're the same bulbs as the dashboard in the Supra, and having just overhauled it, i had a few Xenon White ones spare - so all good now - only three more issues to sort out now; the electric windows, the rusty sills (which are still solid, just grotty looking, i'm guessing zip wheel it, skim filler over the top, sand back, prime & spray?) and the sunroof - which works fine, although the seal is mossy and green, and turns out is responsible for letting all the water into the car...
Getting all the documents for export from the Isle of Man doesn't seem to be too much of a problem either - fill in, post off with a cheque, 21 days later the car is mine, on paper :)
Good little car this, excellent on fuel for sure...what sort of MPG should i be expecting in reality? I'm just under 1/2 a tank now, which, in a Supra, would mean 'find a filling station within the next 60 miles', but i dunno how large the tank is on this!
I'm also new here fella ... and like you my Polo has been stood still a while :/ ... red like yours, pretty much identical ... mines the 1043cc though lol (44hp) ;) ... I'm just starting to try and get her through an MOT ... fingers crossed :)
Sam
Awesome find!
Well done on that.
She looks well, good luck.
Welcome aboard, get some pictures up after a good old clean!
